Display spoil after refurbish lcd.
Hello, recently when I'm doing refurbish 6s/6s Plus LCD I found out that everytime I done cleaning the oca on the LCD after removed the polarizer then the ribbon spoil. I found it when I'm doing the last check before put into the machine. The problem is when I touch the LCD ribbon or trying to flip gently the display gone strange. I was wondering is it the oca remover caused it or the static. Please help!
Update (03/27/2017)
This is the problem when you touch the flex or flip it.
4 Comments
If the problem not serious the LCD still usable.
by Ong Kim Sheng
What does the LCD look like exactly? Can you post a photo? When you remove the polarizer the static line at the top is usually also removed. Which causes a ghosting effect until it is re-applied later in the refurb process
by Andre W.
Question updated. Is this what you called it ghosting effect?
by Ong Kim Sheng
I used 8333 and zippo to clean the oca glue after removed the polarizer.
by Ong Kim Sheng
