No lights, no codes, wont run, intermittent
The buttons on the control panel at times, only some are unresponsive. Then all lights are off and machine is inop. Did a power disconnect, no change. Held the drain/spin button for 3 seconds and control lock light came on, held again controls unlocked and machine operates. Do I have an intermittent problem in the user interface? I have read all 24 pages on this thread and no answer to my question.
Model # 110 2644832 202
2 Comments
I used a technique that has served well diagnosing intermittent automotive electronics. I whacked the control panel with an open hand and it has worked fine since. Probably from "tin whiskers". Google it and you will understand the cause of lots of intermittent electronics.
by den25joan
den25joan, The old one/two slaparoo, I have used this in the past my self :-)
Thanks for posting back, Good luck with your washer.
by L Pfaff
