Bios password, System disabled code 67633417
I m stucked at bios password....system disabled code : 67633417, compaq presario cq42...plz help
You would need to remove the CMOS battery and the actual battery to reset the BIOS and hope that that fixes it. The cmos battery is a little silver disk probably under the ram cover on the back. Remove the ram cover and the battery if its there. Once its removed and the main battery should have been removed before you even started. Make sure its not plugged in to the wall either. So just wait around 30 minutes or so and then put the CMOS battery, and the actual battery back in and see if that fixes the issue. If it isnt under the ram cover, Look up how to remove it.
Hope this helps and good luck fixing!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 700
