Hi,
Create a USB recovery drive. This can be done from any working Win 10 PC or laptop. Go to Control Panel > Recovery and find the link to create a USB recovery drive.
You will need a 4GB (8GB is better) USB flashdrive and about 40 -60 minutes of time to create the recovery drive.
When created change the boot order in your laptop to USB as 1st option, (is it F12? on startup or try F2 and find it in BIOS) insert the USB flashdrive and then restart the laptop. When in recovery environment menu select Troubleshooting > Advanced > Repair this PC.
DO NOT select reset.
Hi @Anamoo,
Here is a link that may help you. It details how to change the boot order if you cannot get into BIOS on startup. If this works then you can use the USB recovery drive that you hopefully have made. (A USB should work you shouldn't need a USB - DVD drive)
If this also doesn't work then the only other thing I can think to try is that you have to open the laptop and either remove the HDD (shown 3:45 minutes into video) and then hope that you can get into BIOS with it disconnected and then look for a setting called "Boot Mode", "UEFI Boot", "Launch CSM" or whatever else it may be called, change the boot mode from UEFI to Legacy/CSM: disable the UEFI Boot option and enable CSM Boot support, select USB as the first boot option, re-install the HDD and then try again to boot from the USB recovery drive, or that you find the CMOS battery or CMOS reset jumper on the motherboard, remove the battery or link to reset the CMOS back to default values and then try to get into the BIOS to change the boot order to USB 1st.
8 Comments
Does the blue screen have an error codes or anything else at all.
by George A.
The blue screen says enter this stop code then it shows a code, it also changes every time it pops up
by Anamoo
Hi, Try starting in safe mode and see if there is anything left of avast to uninstall. Look in Control panel > programs and Features.
If you can't get into safe mode try the following:
Start laptop, when it starts to boot into Windows , force shutdown by holding the power button until it shutsdown. Do this 3 times i.e start - boot - force shutdown - start - boot force shutdown etc. By the 3rd attempt Windows should boot into the Windows Recovery Environment.
Select Troubleshooting > Advanced > Repair this PC and see if it repairs it if not try the same procedure and select Safe mode.
DO NOT select "Reset this PC" as this will ERASE all your data and reinstall Windows.
You can also download Avast Clear to completely remove avast. Instal it in safe mode and run it from there.
https://www.avast.com/uninstall-utility
by jayeff
It still does the cycle. The problem is that my laptop doesnt go into the automatic repair and when it tries to, the PC needs to be restarted screen pops up again then the cycle repeats
by Anamoo
can you remove the battery on this laptop?
by Jimfixer
Show 3 more comments
