Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1501 Questions View all
Screen not working with new Digitizer/LCD
hey guys,
I have an Iphone 3G. The touch screen stopped working. I replaced the LCD/Digitizer, but alas, that did not fix the issue.
So I'm presuming next case - The whole logic board needs replacing?
I have a 3gs here, that I can use for parts (it completely works - apart from the fact that its IMEI blocked).
Can I salvage anything from the 3GS to replace the whatever broken part it is on the 3G to get my 3G working again?
Thanks.
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
no, the only compatible parts are the headphone jack and the rear case. possibly wifi...
sorry
try hard reset or dfu, failing that a pretty good clean of the connection and inspection for damage may solve your problem
Score 2
Comments:
pollytintop is absolutely right. Do not try to interchange any other parts but the ones mentioned. Good luck.
by
Add a comment
you can also use the frame of the 3gs with the home button and ear speaker..but i dont think youll have much luck with that....id try what pollytintop said...hard reset should fix it...
Score 1
Comments:
forgot the frame. brandon is right!
by
Add a comment
http://haffow.com
Add a comment
http://haffow.com
Add a comment
Add your answer
Joshua will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,370
