Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Screen not working with new Digitizer/LCD
hey guys,
I have an Iphone 3G. The touch screen stopped working. I replaced the LCD/Digitizer, but alas, that did not fix the issue.
So I'm presuming next case - The whole logic board needs replacing?
I have a 3gs here, that I can use for parts (it completely works - apart from the fact that its IMEI blocked).
Can I salvage anything from the 3GS to replace the whatever broken part it is on the 3G to get my 3G working again?
Thanks.
Score -1
Add a comment
Chosen Solution
no, the only compatible parts are the headphone jack and the rear case. possibly wifi...
sorry
try hard reset or dfu, failing that a pretty good clean of the connection and inspection for damage may solve your problem
Score 2
1 Comment:
pollytintop is absolutely right. Do not try to interchange any other parts but the ones mentioned. Good luck.
by
Add a comment
you can also use the frame of the 3gs with the home button and ear speaker..but i dont think youll have much luck with that....id try what pollytintop said...hard reset should fix it...
Score 1
1 Comment:
forgot the frame. brandon is right!
by
Add a comment
http://haffow.com
Add a comment
http://haffow.com
Add a comment
Add your answer
Joshua will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,379
