Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
4177 Questions View all
No cellular service, very weak wifi, no water problems.
My iPhone 6 lost cellular service (No service) and it has very week wi-fi reception (2 bars when next to router - none with a wall in between). I've replaced SIM without success; SIM works on other phone. Phone hasn't been in water, but a light drop on top left corner that chipped glass. Can the antenna go bad or become disconnected? Any other possibilities?
Comments:
Thanks you so much! Is the baseband chip replaceable? I'll check wifi connections later.
by
that chip is specific to each motherboard, the solution would be reballing the chip. A micro soldering job, a little bit more complicated.
by
Add a comment
1 Answer
Chosen Solution
The wifi antenna disconnects sometimes due to shocks but only way to see that is by removing the motherboard from the phone and check the connection.
For the cellular part you can do a quick check by dialing *#06# if the IMEI n* shows is the antenna if doesn't show then you have a baseband chip issue.
Score 3
Add a comment
Add your answer
sace99 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 50
