Ipad will not turn on after replaced digitizer
Hey! Now I just replaced the digitizer and was finishing up when I realized I should to check that the iPad turns on. It doesn't and I have tried plugging the iPad into my macbook but it does not recognize that there is anything plugged in. Any suggestion?
7 Comments
I may have not turned off my iPad and so it might be dead D: if so is there anyway that I can fix it?\
by Cameron Parker
Hold down power and home button until the iPad comes on, if it doesn't come on after about 20 seconds, try leaning it on charge for a good while.
by rayeasom
Did you unplug the battery when doing this? If you did, did you use a metal or plastic spudger
by Cameron
Cameron, I may have not unplugged the battery.
by Cameron Parker
If you didnt, you probably shorted something in which case your iPads done. Try putting the old digitizer in and see if it works
by Cameron
Show 2 more comments
