Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
3489 Questions View all
iPhone 6 replace screeen
Hi........
I replace my iPhone 6 screen and when i press power button there was no display the screen black
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Go back to this guide and double check that you did everything correctly. A common problem is forgetting to disconnect the battery before removing the screen. In some cases you can blow the backlight circuit.
*Double check your connections
*Connect your phone to a computer to see if itunes recognizes it.
  • If it doesn't, inspect the connectors for damage or loose/missing components next to them
*Check to see if the screen works by shining a flashlight to see if there is a dim image. That would be indicative of a blown backlight circuit. This is not a DIY fix and requires micro-soldering.
Check this out and get back to us.
Score 3
Add a comment
even my old screen there no display and no power
Add a comment
Add your answer
naim.alabdallah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 73
