The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3363 Questions View all
Will replacing the iPhone screen fix an iPhone's screen touch?
I water damaged my iPhone 5, and I have been phone less for about a year. Due to finicial problems I can not get a new phone soon. My friend says he has an old phone that doesn't work because the touch screen won't work. I was wondering if I could take his faulty screen and replace it with my iPhone's screen. If I replace his screen with mine, will it fix the touch on his phone?
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
No idea. Only way is to try it out.
Score 1
Comments:
The thing is I wanna know if it will work before buying the tools and screen parts.
by
Open up and take pictures of the inside of the phone especially the screen FPC connectors on the logic board. If we think there are no signs of liquid damage or physical damage inside then it's a good idea to try another replacement screen.
by
Add a comment
Most Helpful Answer
it should be of the same model, if your iphone's screen connectors was not corroded due to water damage, then it is possible that it will work out.
Score 3
Comments:
Thanks you, it's very helpful
by
you're always welcome :)
by
Add a comment
My advise is just try to switch your screen whit the faulty one from your friends phone, you don't have to spend much money on tools and parts. You only need a pentalope screwdriver and a suction cup to test the screen and if it is working then you also need a philips screwdriver.
Score 2
Comments:
Thanks for your help!
by
Add a comment
I do not like your odds. Its probably the screen connectors itself. :( maybe buy a cheap screen from ebay?
Comments:
The thing is I wanna know if it will work before I buy the tools and screen parts
by
If it was dropped?
by
no I do not think it will work. Best bet is do go with ebay
by
Add a comment
Add your answer
DJ and Joce will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 84
