MacBook Pro models with a 15" display
5658 Questions View all
Can I change sd-slot?
Hi, my sd slot don't woork in the right way. Can i change it?Thanks. If it's possibile i can buy the repair part here?
P.S.: My MacBookPro is over of warranty.
Thanks for all...
Comments:
What model of MacBook Pro do you have? You can use our ID-Your-Mac guide or you can use EveryMac to help you.
by
Add a comment
1 Answer
Chosen Solution
That slot
is part of the logic board. Like all the other ports and the Graphics Chip it's not really a user replacement item.
That's not to say it couldn't be done, but you'll find it cost prohibitive to:
A). find a replacement part and
B). find someone with the skills and equipment needed to replace it.
IMnsHO it would make more sense to replace the logic board, OR if that's the only problem get an external (USB) card reader.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Score 3
Add a comment
Add your answer
Paolo Mancuso will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 55
All Time: 3,684
