My screen has color all over the screen how do I fix it.
my screen has color lines all over the screen how do i fix it , do i change the digitizer or the lcd when i take pictures or screenshots it looks good.
2 Comments
Also, hold the power button plus power down button at the same time to take a screenshot.
by
Add a comment
1 Answer
Chosen Solution
Because your screen is cracked, it is interfering with the display. I do not know if you screen (digitizer) is fuzed with the display (screen). You will need a replacement of both. If I where you, I would go to eBay and buy the parts with the best reveiws. I cannot aid with the actual replacement, but I suggest looking on YouTube for a tutorial and looking at other devices screen replacement guides to give you an idea. Hope this helps!
Score 2
2 Comments:
hi. if the digitizer isn't fused do i change only the digitizer?
by
You still need to change both. If that crack is from a drop, the drop also affected the LCD.
by
Add a comment
Add your answer
precious_1412 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 448
