iPhone always turns into Recovery Mode after Display replacement
I replaced the screen of a iPhone 6s. It was reseted before I started the replacement. First of all I checked if the new Display would work so I only connected it before I installed it. After the replacement all the cables were connect (Frontcamera Homebutton:by the way I did not change the home button only the display). I started the iPhone and it boots into recovery mode.
I tried multiple times to flash the system but it always fails. While flashing the phone reboots and then the "restore" screen comes again and the software ( I tried with 3u tools and iTunes) failed to flash the system. Then i decided to flash the software without the three cables from the display assembly. It works, but when I turn it off and reconnect the cables. When I restart the phone now it boots into recovery mode. I tried it multiple times with iTunes/3u tools.
What could i do ? What is the failure?
Thanks for your help!
1 Comment
I was having the same problem as you. My iPhone kept rebooting on `recovery mode`.
However, when I have the home button flex disconnected to the motherboard everything worked normally after that.
And I am also noticing that my Home button is always sending a `Hold/Pressed` signal to the iPhone.
Though all, I am happy I have my phone working
by Monero Jeanniton
