Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Questions View all
6s plus losing Touch ID after screen replacement.
I've replaced many iPhone screens, transferring the button to preserve the Touch ID, but this is the third 6s+ that I've replaced and all three have failing Touch ID, even with the original button. Is there something unique about the 6s+?
1 Comment:
Did you checked the ribbon that goes from button to the logic board?
by
Add a comment
1 Answer
I have done quite a few 6s Plus's and have never had an issue with Touch ID so as far as I know there are no unique quirks to them when it comes to the home button other than the usual (don't damage the ribbon cable, remove battery and drain power before removing connector ect.)
Are you using OEM or aftermarket screen? The home button cable is built in to the screen assembly on the iPhone 6s Series and the aftermarket screens frequently have issues so if your using aftermarket screens you may need to switch to OEM to avoid this issue.
Also make sure the cable is not damaged and is seated correctly into the board connector, if the connector is not quite fully connected then you will get the click function but not the Touch ID.
Add a comment
Add your answer
Garrison Babbitt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 154
