Guides for small kitchen appliance repair and disassembly. Kitchen appliances have long helped people fix dinner. Return the favor, and the fix your appliances when they break.
3523 Questions View all
Spindle on Cuisinart turns, but blades don't, even if carefully placed
Spindle on Cuisinart has flat side; blade shafts that fit over spindle do too, but don't turn even if flat sides are carefully matched. Motor is OK, and spindle turns without blades.
Add a comment
1 Answer
Most Helpful Answer
@buzz31 , Maria, If it is just press fit, it sound like the collar on the blade is worn and is not able to fit tightly on the shaft of the motor any more, maybe it has a crack(especially if it is just plastic). This is something you could try if not cracked, with a pair of pliers gently and carefully try squeezing the shaft on the blade a little in the flat spot area to tighten it up or use your make and model # to do a search for replacement blades. Good luck.
Score 2
Add a comment
Add your answer
Maria will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 30
