We are getting an D09 error code. Also hear a grinding noise.
Washer just stopped and is full of water and wet clothes.
Andrew Welker , Found nothing referencing a D09 error code for Kenmore Elite HE3 Washing Machine. Find a link below to your service manual for Kenmore Elite HE3 washing machine which should be help in diagnosing your issue.
F09 error code- Overflow Condition. If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared.
Unplug the unit to service.
Potential Causes
•Check the drain hose and make sure it is not plugged or kinked
•Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
•Check/ Clean Drain Pump Filter of foreign objects
•Check for Drain Pump Failure
•Check the Inlet Valve for proper shut off
•Check the Pressure switch for proper operation
Good luck.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 179
