2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
134 Questions View all
MacBook Pro 15" 2015: Poweron-Pads Location
Hi,
I need the Location of the Poweron-Pads of my MacBook for an external Poweron Solition.
Hope you guys can help me.
Thanks!
Comments:
Patrick Ck post some pictures of your logicboard with your question. Use this guide Adding images to an existing question for that. It will allow us to possibly point it out to you. It may not necessarily have power on pads but can be powered on through the keyboard connector.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
You have to short pin 5 (from the left) of the keyboard connector to ground momentarily. There are no pads on the Retina 15 2015
Score 1
Comments:
I already knew this, but this way I can't power it on when the Lid is closed.
by
When the MacBook is working normally, you cannot power it on with the lid closed, since you cannot press the power button. Solution: open the lid when turning on, or replace the keyboard, if this powers on fine when shorting the pin :)
by
As mich as i know you can power it on when lit it closed whit the Poweron-Pads. Since my Model has no Poweron-Pads i have to Power it on and close the Lid after. :(
Thank you anyways.
by
Add a comment
Add your answer
Patrick Ck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 62
