Microphone not working properly.
Microphone not working properly, been told it sounds muffled or breaking up. Can hear fine. Very frustrating. Anything I can do?
Hi,
Try using the earphones with the microphone attachment and make or receive a call.
If you cannot be heard properly there is a problem with the voice transmission circuitry in the phone on the systemboard.
If you can be heard properly you either have a faulty internal microphone, a loose internal microphone or perhaps the voice 'inlet' hole at the bottom of the phone has become blocked with lint.
To check the last possibility, use a strong light and a magnifying glass to see if the hole appears to be blocked. If it does DO NOT use a probe to try and clear it. You may damage the microphone which is directly behind it. Try using a vacuum cleaner to suck the obstruction out
If this doesn't work then here is a link to a video which shows how to dis-assemble an Asus Zenfone 2. Hopefully it is close enough to your model to be of some help, so that you can check the microphone and the 'inlet' hole.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,792
