Released November 2010. Identified by model number BNRV200.
15 Questions View all
Nook does not charge, I tried replacing the power adapter and cord.?
I tried changing the power supply and the cord ,still does not charge. Could it be the power port? If so can it be replaced or repaired? The battery has been replaced September 2016.
Score 1
Add a comment
1 Answer
Most Helpful Answer
@dickedata , Richard , Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue one more time. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the Nook to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board. you can google search for new charge port if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
Nook Color Motherboard Replacement
https://www.youtube.com/watch?v=Ov-HACi9...
Score 2
Add a comment
Add your answer
Richard will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 52
All Time: 780
