What size screw do I need to install to the stand
i have a westinghouse 55 inch tv,model DWM55F1G1, what size screw do i need to install to the stand it came with
M4x16mm did the trick, in case anyone else shows up looking. I measured about 19mm for the holes in the TV itself, add 1 or 2 mm for the thickness of the base, so anything up to 20 or 21mm would probably work as well.
Made an account just to say thank you for this, not sure why they put “4*14PM” in the booklet as if anyone knows what that is
@kpayne332 , karen payne , If new purchase, the (10)screws should have came with the TV in the box, if they were not contact the store and perhaps they can take them from another box and give them to you. Fix the stand support to the TV using (4pcs) screws and stand base to stand support installed with (6)screws is all the manual(1st link) tells, not the size. If needed use the 2nd link Westinghouse parts request to get your replacement screw's or contact them for exact type and size so no damage will occur. Good luck.
This answer is not useful at all.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 34
All Time: 4,924
