Released September 25, 2015. Model A1687/A1634. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
262 Questions View all
Touch ID not working
Hi
I have recently replaced the screen on a 6splus and all is well except for the touch ID. It's definitely the original home button and I'm confident I haven't damaged it during the replacement, I have repaired 100's of iPhones now and never had this problem before.
It's working as a home button, it's just the ID function that's not working, I have tried putting another screen on but that didn't solve it. When you go into setting the touch ID tab is disabled and fails when you try to turn it on.
Whenever touch ID has failed in the past a reboot always sorts it out, but not this time. The software is up-to-date so it's not that either.
Help!
Score 1
Add a comment
1 Answer
Hey the display you fitted did it come with a metal backing plate on the screen? Or did you have to move it across from the old screen?
Comments:
It had the banking plate, I just moved the heat shield across.
by
Add a comment
Add your answer
Susan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 76
