Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4498 Questions View all
My iPhone 6 wouldn't boot up.
My iPhone 6 was left charging overnight (which I normally do, and so do alot of people in this house) but when I woke up, it was stuck in this apple logo boot up, I searched up for information for this problem but whenever I try to even turn it off, it goes to the battery empty screen, which is the screen that I usually get since I can't even go to DFU mode for it keeps on going on that screen, but when I just leave it charging once again on my pc, it goes to the apple logo, then just stays there, flashes black for a second, and apple logo once again, if anyone knows how to fix this, please do reply immediately, I also don't need the files that much here, I just need to use this phone.
Add a comment
1 Answer
Chosen Solution
It sounds like you have either a defective battery or charge circuit.
Do you use a genuine Lightning cable and charging brick? Fake ones can let transient high voltage noise get through and damage the charging circuitry on the logic board.
The first thing you should try is a new (or known-good) battery. Order them from iFixit as there are a lot of low quality batteries out there. If that doesn't work, then you could also try replacing the Lightning Port. Always use genuine cables and bricks.
Then try to recharge the battery and see if it works.
If the problem is on the logic board, then you will need to find a repair shop that does micro-soldering repairs.
iPhone 6 Replacement Battery Image
Product
$29.99
iPhone 6 Lightning Connector and Headphone Jack Image
Product
$24.99
Score 1
Add a comment
Add your answer
kcmagno4 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 54
