Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 Questions View all
Logic board has dicloleration (reddish) on the underside of the Intel chip
Here's what I'm talking about 2417 I-7 core to duo
Charger connects light on and no start up, no power, only blinking battery indicator lights......
Is this a overheated logic board????
Thanks for the info everyone!!!
7 Comments:
@talmadge , Talmadge Dowse, Smell the chip/board, if it smell burnt/weird it is probably bad.
by
No burned smell, someone didn't exactly know how to take apart the battery connector was half ripped up and the track pad was not in level etc....It was part of a donation from a friend that owned a hauling clean up service
by
Its probably going to need a new board
by
@talmadge as @lpfaff1 is suggesting, it sounds like someone has reflowed the chip, so it was likely experiencing the common GPU issues on the 15" 2011 models.
Just replace it with a 2012 board to be honest, no point wasting any time trying to fix this one.
by
Show 2 more comments
Add a comment
1 Answer
That sounds like a battery needs replaced or the volt regulator or capacitor or some sort of electronic part needs replaced.
1 Comment:
Thank you for this info.
Im appreciative, these Logic Boards are prone to video chip problems as well, So I might just upgrade to a 2012 model Logic Board since its the same btw
Thanks very much!!
by
Add a comment
Add your answer
Talmadge Dowse will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 73
