Replacing Home button & Finger Print functionality
I have replaced my iPhone 5s home button
the home button worked fine but the fingerprint not working
and every time i restart my iPhone it showing a message stating "Unable to activate Touch ID on this iPhone".
Someone said:
The home button that comes with the iPhone is the only home button that will work with the fingerprint scanner, any other after market home button that you put in your iPhone won't work as fingerprint scanner, but just as home button.
is that correct ???
2 Comments
Even if you get a original home button from another iPhone touch ID won't work anyway.
by Ben
error "unable to activated Touch ID on this iPhone" when they are replaced. My iPhone 5s didn't show that error, but when I hit "add a fingerprint..." menu, it show next page, but next nothing happen when I put my finger on Touch ID, any idea whit this? Error show only when I try to turn on the phone with flex cable disconnect from logic board, last try hard reset, restore, install IOS 10.3 then back to iOS 10.2.1, disconnect battery connector, nothing fix
by Ary NW
