Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
338 Questions View all
It just doesn't make sense!
Custy brought in iPad mini 2. She said she did the repair herself, worked fine for a year and a half. Then after updating the home button stopped working. When I tested it at first, the power button isn't working, it charges but the display won't come on, home button still doesn't work. Decided to put a new glass digitizer on, put it into dfu, works just fine! Except when plugged in, at first it says charging, then after a second or two, says not charging
Score 1
Comments:
Or a bad charging IC.
by
Yeah, but does all that other stuff work? The power button? To simply turn it off and on? Sorry, sleep/wake? Also, everything works great, with the new display
by
Add a comment
1 Answer
Chosen Solution
If you troubleshooted all the rest, power cable, charger, as I believe you did, there isn't much else left between power and the battery, you have the charging port, the solder joints where the port joins logic board and the Ic(s).
Score 1
Add a comment
Add your answer
iMedic will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 91
