Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Why wont my iPhone 6 turn back on?
Hi ifixit family , my iphone won't turn back on. It died and it showed the dead battery logo. When i put it on the charger it didn't turn back on. I let it sit on the charger overnight and still won't turn on. I tried to hard reset and it still didn't work. Help !!!
Add a comment
1 Answer
Chosen Solution
first thing id try is to check if the lightning cable goes all the way in and sits flush inside the phone, if its sticking out a little, cleaning out the lightning dock will likely solve this problem.
next id try changing the battery, then the lightning port, if neither of these solve the problem then its likely a logic board issue..
there are guides available on here to replace the lightning dock and battery.
good luck
Score 1
1 Comment:
thank you! hopefully it does work out
by
Add a comment
Add your answer
Justin Vicente will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 80
