water damaged phone wont turn on and not flashing on pc
My motorola moto g4 plus was damaged by water splash.
From then the screen wont turn on nor the charging screen appears
Only the white led light appears as i connect the charger.
I would give it to the service centre but my whole data would be lost that way
I want to first backup my data but my phone is not flashing on the PC storage.
Any thing would help!!!
Add a comment
Most Helpful Answer
Kepler-b 68 , As Tim recommended, do not try to charge or turn on the device until as this can cause further damage(shorting), thoroughly take apart Moto G (link#1) and using the Techniques for generalized water damage troubleshooting and recovery guide (link#2) to clean up liquid/corrosion from the board and connections. Good luck.
https://www.youtube.com/watch?v=K9zMlwRf...
Electronics Water Damage
Score 4
1 Comment:
Love your 67 Camaro pulling wheelies! I have a 68 here in London, England and have fitted Caltracs bars, a 9" rearend, a reverse pattern manual valve body T400 and about to fit a 565 cu.i. making 975HP built by Steve Schmidt in Indianapolis. I have a water damaged Motorola G5 and need to recover data from it. My email: rfbannister@hotmail.co.uk, Many thanks!
by
Add a comment
First, stop trying to turn on the device or plugging in a charger. Keep it off. Then follow this water damage guide: Electronics Water Damage
If the phone still doesn't work, there are technicians that specialize in data recovery of water damaged phones. Do a google search, and you'll find some.
Score 1
Add a comment
Add your answer
Kepler-b 68 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 641
