Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
122 Questions View all
HELP! Oneplus One reboots after each light collision.
I accidentally dropped my Oneplus One. Now every time when i bump my phone or it shakes a bit in my pocket, the phone reboots. I can't do anything with my phone this way.
I don't know how to fix this but i hope you guys can help me a little bit..
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
@joentje64 , Use the disassembly guide link below, you can open your device to check for loose connections and reseat them which may be your issue. Also check for other loose or damaged components/parts which you may have to replace. Good luck.
OnePlus One Display Assembly Replacement
Score 3
Comments:
Thank you for your help, i will disassembly the phone right now.
I'll let you know if i find anything.
by
After a while my Oneplus one went completely dead and goes in a boot loop when charging. I opened the phone and clicked all connectors lose and put them back on. Removed the battery and put in back in. Now my phone is back up again! Hope it will last. Thanks for your quick reply!
by
@joentje64, Thats great! Thanks for replying back, good luck with your device.
by
Add a comment
Add your answer
joentje64 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 48
