water comming in from the waste outlet when water in my sink
water coming in my machine when not on from my waste pipe
sherwoodys , Sound like the washers drain hose may not be correctly installed. You must have the wash machines waste hose elevated/installed higher then the top of sink. Also check the drain/sewer line for blockage and remove blockage as waste water should not be backing up. Use the links below for more info. on your issue. Good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 52
