Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3260 Questions View all
Where are the iPhone 4 antennas' feeding and grounding points?
What sort of antenna does iphone 4 employs? Is it an IFA (inverted F antenna)? I tried to find the feeding and grounding points, particularly for the wireless antenna (WiFi, Bluetooth and GPS).
Usually and IFA has a feeding point somewhat in the middle. Unfortunately, I cannot find it. There seems to be a feeding point close to the top slit.
Is it possible then to achieve dual-band behavior? How many grounding points are there, and where?
thanks
Comments:
This question was migrated from http://meta.ifixit.com/.
by
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Chosen Solution
Looks like its all a big secret. Here is some info on the antenna but not sure if this will help you in your quest. http://www.anandtech.com/show/3794/the-i... some more neat stuff here http://robertthorpeconsulting.com/wordpr... and here http://www.wired.com/epicenter/2010/07/a... and here is some more really interesting reading http://forums.macrumors.com/showthread.p... Hope this has the info you wanted. Good luck.
This image shows the feed points
Score 1
Add a comment
Add your answer
jenni will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,184
