Unibody MacBook Pro models with 13" displays produced from 2009-2012.
4630 Questions View all
Do I need to perform a power management system calibration?
Hi.
Replacing my battery seems pretty straight forward however I have seen other tutorials stating that a power management system calibration is necessary for optimum battery power. Yes or No and why.
Thanks so much.
Add a comment
1 Answer
Chosen Solution
Yes it is. Because you got a new battery, it isnt calibrated and if its not calibrated right your laptop could say it's at 25% even though its at 3%. Its actually really easy to do. Charge the battery all the way up. Let it discharge until the laptop dies, charge it up again and it should be calibrated. If it isnt and it dies before it says 0% just do it again but charge,discharge,charge,discharge,charge then it should definitely be calibrated properly
Hope this helps and good luck fixing!
Add a comment
Add your answer
Jennifer Lemay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 208
