Digitizer not working correctly. Some spots are dead, some are offset
I installed a new screen & digitizer. The Digitizer is not working correctly. Some spots are dead, some are offset. Like if you press "a" you get nothing. If you press "s" or "d" you get "a". To use the "Slide to Unlock" you have to swipe downward at 30-45 degree angle. With "Slide to power off" the first 75% of swipe doesn't register and the last little bit isn't enough to turn it off.
