Released September 25, 2015. Model A1687/A1634. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
420 Questions View all
Replaced Screen as was cracked, now no image! just white light.
Need help.
I have replaced the screen on iphone 6splus with the kit on ebay as it was cracked with black dots on it.
However when replaced, i noticed the black (which i presume is a sticker) wasnt provided? is this normal? its on the front screen.
So when its off, you can see the glass silver look instead, rather than the screen going ALL BLACK. Any reason?
Also theres no image, so is this related? When its on, i can hear sound, but no image, just white light.
ANy help?
Add a comment
Chosen Solution
Sounds like a low quality aftermarket screen if it has the silver reflective finish on the screen. The last time I had this was when buying cheap iPhone 4 screens from last year.
Also probably a bad screen, does the old screen still have display? Make sure to unplug battery prior to plugging or unplugging ribbon cables if you didn't know already.
Score 2
The old screen broke even more (as it was allready cracked) while i was taking this off. So its completely gone now. Is it worth while trying the whole thing again and take off the battery? As it has a silver finish, can it still in theory work?
Add a comment
You definitely got a low quality part. You can buy good quality repair parts from iFixit or a number of other places such as Mobile Sentrix, Injured Gadgets, Revamp Wholesale, eTrade Supply etc.
White light usually means the backlight is fine, but the LCD itself is no good.
Score 1
Add a comment
Add your answer
Ali will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 74
