My tablet doesn't charges and turned off
Hi,
My tablet (Huawei mediapad t1 8.0) doesn't charges and now it turned off also when it was on It cannot connect to my PC although I install the drivers what is the solution? please help me.
Remark: the charging port is good.
Comments:
Try leaving it to charge overnight or an entire day. Also try using a different power adapter and cable
by
Add a comment
1 Answer
Chosen Solution
Hi,
You cannot charge via USB, you cannot connect via USB.
How do you know that the charging port is good?
It may look alright from the outside but it may be disconnected from the systemboard on the inside.
If you have tried different cables and different appropriate chargers and since you haven't specified how you know that the port is OK, then the tablet needs to be opened and the USB port tested to prove that is properly connected to the systemboard.
If it is loose or disconnected at all and as most probably it is a SMD (Surface Mounted Device) type USB connector, you will need the requisite tools and expertise to solder it back on. If you have never done SMD soldering before, I suggest that you contact a reputable, professional mobile phone repair service and ask for a quote for the repair. In the long run it may be cheaper than if you try do it yourself. You may cause more damage than what you had before you started, especially if you don't know how to do it.
Score 1
Add a comment
Add your answer
ooo3 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 157
