The Pixel is Google's first phone released in October 20th, 2016.
8 Questions View all
How to fix cracked corner?
I am using google pixel silver variant , my phone hit the floor and its top corner is damaged , is there any way to fix it?
Add a comment
1 Answer
Chosen Solution
@ruchir1708, Ruchir , The truly only way to fix properly would be to replace the damaged piece, I assume it is your display that is damaged. Google has partnered with tech repair chain uBreakiFix and screens that I found through google search are more then $130.00, may take some time before you find a more reasonable screen assy. The link below sometime have parts but seems to be hit and miss at most. You could check places like Ebay, Amazon, etc. some times they have good used parts. Sorry I could not be of more help. Good luck with the repair of your Pixel. In case you locate the part I will post a couple links to show what is involve in disassembly of a pixel phone. Good luck.
https://www.esourceparts.ca/index.php/ce...
https://www.youtube.com/watch?v=0tKNn_w3...
Google Pixel XL Teardown
Score 2
Comments:
Thank you very much for the reply L pfaff ! The screen isn't damaged . But the corner metal body has got a big dent , i need a solution for that .
by
@ruchir1708,Ruchir, Perhaps you can disassemble it, I do not think the metal would be very thick, so use a pencil with hard eraser to press/manipulate the dent/damage out the best you can. If you feel that disassembly could cause more damage, may just want to live with the dent if just cosmetic. Good luck.
by
Add a comment
Add your answer
Ruchir will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 14
