Unibody MacBook Pro models with 13" displays produced from 2009-2012.
4628 Questions View all
Would a 2008 metal MacBook screen replace a 2010 MacBook Pro screen?
I have a 2008 MacBook Pro (I'm assuming it's a pro, since it is metal and not plastic) and a 2010 MacBook Pro with a cracked front glass. Instead of going through the painful process of replacing that glass, would the two screen swap ok? I haven't opened it up to look at the connectors, and I can't really find a definitive answer from Google. Being older MBP's, I don't want to invest the $133 for a used screen on top of the $30 I'll have to spend for a new battery.
Anyways, if anyone can shed some light on this, and even link me to some schematics, that would be wonderful. I had access to some, but my subscription expired. TIA!
1 Comment
You'll need to lookup your system to be sure what you have.
Open 'About this Mac' to copy off the systems S/N (or locate it on the bottom cover) and plug it in here: EveryMac - Lookup. Once you know paste the systems URL link here for us to see.
by
Add a comment
1 Answer
Chosen Solution
Found out that the screens swap and work flawlessly. The connector nearest the superdrive is a little shorter on the 2008 screen, so it's kind of a stretch. It plugs in with a little persuasion. I added some electrical tape to keep it is, as it disconnected occasionally during use. One can also remove the "subwoofer" housing by snipping the wire and have plenty of reach, and still have sound.
Add a comment
Add your answer
Kaleb Johnson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 166
