Repair guides for Android cell phones manufactured by ZTE.
1006 Questions View all
What is the service mode code for my ZTE phone?
I need the service mode code to switch on the 800MHz frequency on my phone.
It is a vodafone smart ultra 6, made by ZTE for the UK market.
Anyone has the code?
Regards,
Jerome
Add a comment
Chosen Solution
Thanks jayeff and oldturkey03 but I tried those before.
They allow mods but not to the hardware itself, which I am trying to do.
I am trying to switch on the 800MHz radio on the handset itself.
Jerome
Add a comment
Most Helpful Answer
Hi,
Check that the Network Mode setting is set to either 4G or LTE (not sure how it is listed in your phone).
Go to Settings > Wireless and Networks > more > Mobile Networks > Network Mode.
If you are connected to the Vodafone UK network, LTE (4G) may not be available in your area yet.
Here is a link to check the availability of the Vodafone UK 4G network for your location.
https://www.vodafone.co.uk/explore/netwo...
Update (02/25/2017)
Hi Jerome,
The Vodafone Smart Ultra 6 (Model VF-995N) already has 800 MHz (LTE / 4G) support as far as the specs that I have found state, so it should be available automatically. You shouldn't have to turn it on to receive / send the carrier signal, except as I said by selecting it as the network mode.
You mention that yours is made by ZTE. What model is it if is not the one above? If you can find the ZTE model number on the phone check its specs on the ZTE website to ensure that it even supports 800MHz. If it doesn't then there is no option to make it does so. Altering it to do so would require replacing most of the circuitry involved with the cellular communications signalling section of the phone,(filters, antenna, oscillators - probably all in one IC nowadays plus ensuring the board configuration matches etc) and most probably the firmware as well.
If it is the VF-995N then is the phone unlocked or does the carrier that you are with have LTE (4G) available?
Have you tried another network compatible, known 4G working SIM card in the phone to ensure that the problem is not the SIM card, not automatically providing the correct APN information to the phone?
Score 2
Add a comment
Jerome Lynch try *983*0# and see if it works for your Service Menu code:
Score 1
Add a comment
Add your answer
Jerome Lynch will be eternally grateful.
Past 24 Hours: 14
Past 7 Days: 71
Past 30 Days: 351
All Time: 1,846
