Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3260 Questions View all
After removing some screw's and removing the screen...
Basically i removed my screen and before i screw everything back i checked if the screen is working and it did worked. Then i screwed everything back and i tried to turn it on and i get nothing . i plugged it to my pc and it's shows my phone in iTunes and it's charging. I have no sound and vibration. Please help me what should i do and sorry for my bad English .
Add a comment
Chosen Solution
1. Check the display sockets
2. Try a new screen
3. If not, check if the plugs are damaged
4. If the connectors are damaged, you need to go to an expert repairer
Score -1
Add a comment
Most Helpful Answer
I'm guessing long screw damage after putting a longer screw than required on one of the few screws that screw onto the metal plate to the logic board for the screen connectors.
Score 2
Comments:
But how to fix it ?
by
A regular person can't fix it. I'm afraid you will have to take it to someone that does microsoldering on iPhones.
by
Add a comment
Add your answer
Sandis Zunde will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 66
