1- Did you give your phone a sweep?
If the answer is yes, the problem is caused by this How? There is a protective metal on the top of the processor. It is attached with 4 screws. The size of the 3 screws is the same only if the lower right screw is short. If the mechanic friend holds the long screw on the lower right side, this gives the processor blue screen. Show your device to a good iphone service. If it has not been repaired, continue to read the device.
2- Update your iOS version. Your iOS version may have not been fully loaded and may have been upgraded with missing files. Update your current version. If you keep reading the last version.
3-Get a backup of your phone (make a backup) and then turn off your phone. Press and hold HOME + POWER to turn on the power (7-8 seconds) and then pull your hand out of power (note: do not pull from the HOME key). Connect your device to your computer Open iTunes and then restore or restore your device from scratch.
4- Is your device jailbreaking? If yes, remove Jailbreak 3. Repeat the sequence and jailbreak again.
5) Last and effective method: Turn off your device and turn it on. If you see a blue screen after turning it on again, turn it on and off again and it will open again without any problems in the 5th trial. Download the program from the App Store from the App. Make a few calls, post messages, change settings, do a lot of things. Your device will improve. Despite all this, I can offer 2 alternatives
2 Comments
The device has been repaired recently, eg did the home key change
by Ahmet Can Demiral
the screen has been replaced
by sky
