LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
106 Questions View all
Can the Volume switch be replaced?
Is there an easy way to replace the volume switch? Mine has become water damaged.
Add a comment
1 Answer
Chosen Solution
@princemc , Matthew, If your LG G5 has had water damage, you should seriously consider tearing it down using (link 1 tear down guide), then using (Link #2 guide) to clean the liquid damage/corrosion from being caused on the connections/ board/ volume button ribbon cable connections, etc., this may even correct button issue and if not, at least you will have been able to stop the corrosion and can change the button. Volume button repair vid. last link. Good luck.
LG G5 Teardown
Electronics Water Damage
https://www.youtube.com/watch?v=g9C0xXw5...
Score 2
Add a comment
Add your answer
Matthew Prince will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 35
All Time: 517
