Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2956 Questions View all
Replaced Battery, will not charge even though it shows it is.
I replaced the battery on my niece's iPhone 4S, and attempted to charge it upon completion. Plugged it into a 1A charger and the phone didn't recognize that it, moved the usb to the 2A side of the same charger and it recognized it and showed that it was charging. Next morning the charge showed up less than when I hooked it up, but still showed that it was charging. Tried to reboot phone and hooked it up again to no avail. Tried separate charger and cable same issue. Any ideas would be greatly appreciated!!
Add a comment
Chosen Solution
There may be a problem with the battery you replaced. If your device does not have the necessary electronic information that may be a problem with the charge integration, you can get help from an expert
Score 1
Add a comment
Thanks it was the new battery, replaced and fixed the issue!!
Add a comment
Add your answer
Doug will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 27
