Why is my mobile phone not charging
battery is good,the only problem is when i connect the charger,it does not charge
Score 3
Comments:
My cherry mobile cubic morph he charge up to 66% only
Plss help me how to fix it
by
Add a comment
1 Answer
Chosen Solution
byahero_132 , We really do not see this phone in North America. Since you state you know battery is good, either the cable or battery connector(link #1) may be damaged. Look at the charge connector and blow/pick out/ wipe any dust/debri that may be causing a connection issue. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix, it is probably a damaged/loose charge connector that will have to be repaired/replaced. Sorry was not able to find guides or video's showing the process of repair, you can try a search and may have better luck. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
https://www.maxbhi.com/battery-connector...
Score 3
Comments:
Thank you very much for your response to my query....
by
Add a comment
Add your answer
byahero_132 will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 92
All Time: 1,836
