Battery drain fast even after replacement (6s)
I've changed the battery yesterday(having the same issue with the one that i had before . Checked with coconutBattery had 92% Life, charged only 150 times .. Battery was good but i had to change to SEE if the Battery was the problem ...But it isnt..Battery Drains in Stand-by .in 12 hours max 10 minutes usage battery drains 70% overnight . No internet connection ..3G not LTE .. trying airplane mode still same... reset no applications installed still draining ...what is the problem? I brought the phone second had but I had warnitiy (I went to apple and said them the problems ..they checked my phone I said no hardware problem .. and it was giving back as i sended..now no warnitiy. Someone has this problem?
2 Comments
Might want to check this out:
https://www.apple.com/support/iphone6s-u...
by Ben
The serial number you entered is not eligible under this program because either: - It's not one of the serial numbers in the affected range OR - Our records show that your battery has already been replaced. If you paid for a battery replacement service, check with Apple to see if you are eligible for a refund.
My phone is not turn suddenly down . I've changed battery with a new one witch is better than the original one but still drain fast .. I don't think the battery is the issue
Example: I charge my phone 100 % after 10 hours without touching the phone I have like 30% +- battery left
by Daniel Dorneanu
