Front facing camera mis-aligned with its window
I have struggles aligning my front-facing camera to go co-axial (centered) with its window on the front panel, although the plastic bracket underneath is correctly in its place and the camera is positioned well into the plastic bracket's two grooves. It has no functional effect, the camera's field of view is alright, but it looks silly from the front. Any ideas or experiences regarding this issue would be appreciated. Thanks.
Are you using the plastic gasket that holds the front camera?
by Ben
Yes, I do.. I have just seen a video though where the guy used glue to fix the camera bracet. The problem might be that I haven't used any glue and the bracket slides off from position... Could you confirm? Thanks
by Tamas Korodi
