Why do the codes say all injectors have an open circuit
Where is the injector systems ground wire?
Matt are we dealing with a gas or diesel motor? If its a diesel the injector is grounded at the injector where it goes into the block under the valve cover and each injector is grounded individually. If we're dealing with gas engine there is a common ground that runs the length of the fuel rail and back to the ECM behind the battery.Just another thought ,it's possible for one injector to short out the whole battery voltage feed to all the injectors. So if you have lost voltage to all the injectors, replace the blown fuse and plug each injector in, one by one. If the fuse blows, the last injector you plugged in is shorted. Hope this helps
My 2008 Dodge Magnum 2.7 V6 is saying all six injectors has a open circuit and those are the only code that's reading on my scanner I was thinking I might have a break in the line somewhere because the six injectors I put in it are brand new and it's still flooding the motor because all the circuits are open
Did you ever figure it out my 2007 is doing the same thing
Did you ever find the problem I'm have the same issue on an 08 charger
Did you ever figure it out my 07 charger is saying the same
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 25
All Time: 5,583
1 Comment
How did you determine this? Could you please specify you answer? Did you use an ODB-II tool like this one: https://www.amazon.com/gp/aw/d/B005NLQAH... ?
by George A.
