Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3313 Questions View all
iPhone5 stuck when I install front camera and sensor cables to board.
Hello,
I broke my screen and I replaced the screen and digitizer 1 year ago. I replaced it. It worked fine until last week. My phone's battery was swollen. So I bought a battery and install, it was simple.
When I tried to power up, it stuck at Apple logo. I worried and try to restore from iTunes. It gave error 4005, 4013, 4014... I searched and found some videos, explain the reason may be some defective components.
I started to disconnect connectors one by one, and bingo, it was front facing camera + ear speaker + prox sensor.
When I try while that connector disassembled, it powers up successfully. When I re connect the connector, it stuck.
Before replacing the battery, everthing works fine. I switched to old battery but didn't solve for camera and ear speaker problem.
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
Replace the front camera ribbon cable assembly. It has gone bad.
Guide to replace:
iPhone 5 Front-Facing Camera and Sensor Cable Replacement
Where to get part:
iPhone 5 Front Camera and Sensor Cable
iPhone 5 Front Camera and Sensor Cable Image
Product
$24.99
Score 4
Comments:
Will it be the definitive solution? Is it a guess or fact?
by
I can't answer that unless i have the device in front of me.
by
'When I try while that connector disassembled, it powers up successfully. When I re connect the connector, it stuck.'
What else would it be really?
by
Add a comment
Yes you have to replace the front camera ribbon cable assembly, then only it will work bcoz once i replace the display by mistakely the front camera cable was got damaged and i start connect all the connectors the device was stuck and i replace the front camera cable assembly it worked for me, So pls try it
Score 1
Add a comment
I bought a new camera ribbon cable assembly.
I will try tonight and let you know the result soon.
Thanks.
Comments:
It worked. I replaced the full front camera ribbon cable and works fine.
by
Great you did it nicely
by
Add a comment
Add your answer
Cagdas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 40
