Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone not charging, "this accessory may not be supported."
I have this iphone 6 motherboard that works almost fine, exept it wan't recognise the charging cable, and the message pops up: "This accessory may not be supported".
I have tried "millions" of different cabels, originals too, but it dosn't work.
I can charge it by turning the phone of while it is plugged in, but that is no good...
I have tried with diferent ports too, dosn't make a difference.
I have tried updating/restorering the phone, didn't help.
Could it be fixed by jailbreaking the phone and mabye run it on an older ios?
Could it be the charging chip (U2)?
Thanks for your help :)
Score 1
Add a comment
Most Helpful Answer
one thing that may cause your iPhone to reject your charging cable is that your charging socket/hole/connector may be full of dirt, like lint, or dust. a good way to clean this out is with a toothpick, carefully. alternate scraping the dirt out and blowing in the charger port to loosen the dirt. dirt in the charger hole may cause a poor connection, including the error message
Score 1
1 Comment:
I tried conecting a completly new socket to the motherboard, didn't help.
The problem must be software related or some hardware failure on the motherboard
by
Add a comment
Try a DFU mode restore, if not then it would probably be the tristar chip.
Score 1
1 Comment:
DFU restore didn't help ..
Guess I'll try replacing the chip then.
by
Add a comment
Add your answer
anthonriis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 9,852
