My phone (Xiaomi 5S) dropped into water, now not working.
Dear Mr/Mrs;
My phone (Xiaomi 5S) dropped into the water, now its not working touch and showing
lines. Is it just need to change LCD ?
Dear Mr/Mrs;
Hi,
As you know water and electronics and electricity are not a good mix.
The minerals in the water cause corrosion and the water also provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion process starts immediately and will not stop until it has been thoroughly cleaned away
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% or less and is not as effective. If you do check the label to verify the amount
Here is a link that in general describes the process.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Here is a link to a video showing the dis-assembly of a Xiaomi 5S that may help you
https://www.youtube.com/watch?v=m7ARfsBg...
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 281
