Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
changed battery, now cannot turn off, why?
What part inside of the phone controls on/off? I changed my battery, and now cannot turn the phone off (the click button on the top right of phone does nothing). I am guessing that it has something to do with re-connecting ribbon #5 (this didn't look right when I was re-assembling)...but I thought I'd try things how I had them, then go back if necessary and find the ribbon cable. But now since my phone will not shut off....I don't think I CAN safely take it apart while turned on. Will I short something out if I try to take the phone apart while still powered on?
Score -1
Add a comment
1 Answer
Chosen Solution
May be the safest bet would be to let the battery discharge on its own since the phone is on it should do so relatively quick. This way you won't run the risk of shortening out any circuits. Just my 2 cents, good luck.
Score 3
1 Comment:
Spot on advice! then go and put connector on properly and all should be good.
by
Add a comment
Add your answer
jenk57 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 952
