Will not automatically run spin cycle.
Runs wash cycle the will not run spin cycles. You can run a partial spin cycle manually.
Bad control?
Bad control?
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 65
2 Comments
eric_machuca does it pump the water out before spinning?
by oldturkey03
Most of it. But the clothes are still soaked. I took the back off yesterday and checked the belt, hoses and so on. no clogs.
by eric_machuca
